Hello Aviv,
While you cannot simulate a 5650 as a DAQmx device, you can simulate it using the niRFSG Initialize with Options VI found in the Measurement I/O » NI-RFSG » Utility palette. This VI exposes an additional option string which allows you to set certain qualities for the device. In your case, you will want to set driversetup=Model:5650 and simulate=1. This will set your device model to a 5650 and enable simulation. See the NI-RFSG help file for more information on this VI its corresponding options.
I have attached an example, base on the RFSG 565x Analog Modulation shipping example which simulates a 5650, written in LabVIEW 8.2.1. Let me know if you have any questions.
Message Edited by Speedy Badger on 09-10-2008 09:57 AM
Chris Behnke
Sr. RF Engineer
High Frequency Measurements
