10-24-2008 03:29 AM
Dear Sirs,
The hp 8904A instrement allows to apply negative DC voltage. However,in your driver to this instrument it doesnt succeed to apply negative voltage. I guess, I have to change the string "APA%.2eVL", right?
If yes,how to change it so that it would send negative voltage?
Thanks alot,
Ilya.
10-24-2008 08:37 AM
10-24-2008 11:12 AM
10-24-2008 11:58 AM
10-24-2008 12:46 PM
well done! I also knew from the manual that negative amplitude is accepted only for DC option, but just didnt think about this.
Thank you very much!
p.s. I suggest you to fix it in the drivers of your site - just to concatenate amplitude value after the waveform type and not before as it is now
10-24-2008 01:12 PM
Glad you found the problem. Since it's NI's site and not mine, I can't fix anything and since the driver is unsupported (originally from 1994), I doubt they would do it anyhow but you can never tell.
p.s. I think the idea is to mark the reply that solved the problem - not mark your own reply.
10-24-2008 01:16 PM
Yes,I wanted to mark yours, I marked my reply by mistake.
sorry
