08-01-2017 01:17 PM
I was wondering about DAQ support for PCI 6704 on this link
http://www.ni.com/en-us/shop/select/analog-output-device?modelId=122629
The PCI 6704 does not appear on this NI DAQ legacy list even though PXI 6704 and PCI 6703 do
http://www.ni.com/download/traditional-ni-daq-legacy-6.9.2/824/en/
At one time the PCI 6704 was supported under NI DAQ but not NI-DAQmx, now the opposite seems true.
http://forums.ni.com/t5/Signal-Generators/When-is-PCI-6704-supported-by-NI-DAQmx/m-p/158888
What changed in the PCI-6704?
What are the options for drop in replacement of PCI-6704 cards supported by NI DAQ 6.9.2?
Just wondering.
Thank you.
08-02-2017 05:30 PM
The quickest way to answer this question would be to check the readme for NI-DAQ 6.9.2 and look for compatible cards and then compare the specifications for those cards to the 6704.You will want to check our website to make sure those cards are still available for purchase since that is an older driver and many of the cards might have reached end of life.
http://download.ni.com/support/softlib//multifunction_daq/traditionalnidaq/6.9.2/readme.htm
If you have specific questions about alternative cards, post your question back on forum
Matthew C
NI | AE
