05-24-2010 12:08 PM
What is the best way to generator custom waveform on the NI 5663E sginal generator. I'm able to generate a QPSK signal with 2 Mchip/s but I can't figure out how to get the offset on Quadrature channel according to bluetooth specifications. Does anyone know how to do this?
05-25-2010 01:47 PM
Dan King
03-25-2011 09:02 AM
Hello
I'm making the same and I used the MT RFSG PSK.vi like an example. When I see the spectrum in a spectrum analyzer it is good but if I see it by software (in the graph) is only a baseband signal, so isn't good. I can attach my VI. I think is good to use the FFT Power Spectrum. vi but I don't understand why is different.
Thank you.
03-30-2011 06:04 PM
I ran the code you have an got this:
I don't think we are using the right method to display the spectrum. I'll see what I can find for you - there should be a better way to get the data you are looking for - seems the hardware is working, just need to find the right VI to show this in your code.
03-31-2011 07:15 AM
I'd appreciate to help me because my director doesn't help me anything. He said me that the RF generator modified the signal that I'm generating with labview and I have to model the generator like a VI. I say, I have to do a VI that simulates the funcionality of the generator and then apply it after the signal that I have (after the complex waveform I think) so it should be like a filter and then the signal in software and hardware would be the same.
The problem is that I don't know how to model the generator. I'm working with a RF Signal Generator NI PXI 5652.
Thanks for all.
03-31-2011 11:46 AM
I think you are probably using a different piece of hardware - the hardware supported by this example are: 5670, 5671, 5672, 5673. Either way, I changed some of the settings on the power spectrum VI and I think the spectrum looks more like what I would expect:
I set dB On to true and restart averaging to true:
Is this what you were looking for?
03-31-2011 11:53 AM
No, because this is a baseband spectrum and in the spectrum analyzer I see the signal in the band (i.e 2,4 Ghz the signal appears in the center of that frequency). I think the signal is good, but I don't understand why is center in 0.
03-31-2011 01:35 PM - edited 03-31-2011 01:36 PM
Yes, you are correct. Looking at your code should explain why this is. You pass this baseband signal to rfsg_Resample and Write -
This VI takes the baseband signal and includes the I/Q data and writes this new signal out to your card - hence you are seeing two different outputs. You are monitoring a signal prior to the addition of I/Q rate, so that I/Q waveform is created inside the rfsg_Resample and Write VI and sent to your hardware, and then that signal is what is sent out.
04-01-2011 07:09 AM
ohhh, maybe is true but I cannont monitoring nothing after that VI, I dont't know how to do it. Only I have 3 outputs and 2 of them are the instrument handle and the error out. The output of the adjusted IQ rate/original IQ rate is 1 because is the same, it doesn't change it. I don't add a new IQ rate, I don't understand it very well...
04-01-2011 12:37 PM
So, to simulate the upconvert that your hardware is performing, you can use the Upconvert Baseband VI. Note: you need a baseband waveform with enough samples to do the upconversion. For this, you can use the MT Resample VI to resample and give you those extra needed data points. Here is what it would look like:
Give that a try.
