DonRoth,
According to the help file (NI Signal Generators Help, default path Start Menu » Programs » National Instruments » NI-FGEN » Documentation) under Devices » NI 5411 » Waveform Generation » Frequency Hopping and Sweeping, the maximum frequency hope rate is 333 kHz (3 us), and the maximum number of hops is 512. I am not sure why it is not letting you go down to the idealm numbers, though. Unfortunately, after looking through your specs, it appears even if you getting best case performance, it would still not be sufficient for your application. You may be able to achieve these specs with something like the
PXI-5422, the
PXI-5421 or a third party device (hope that doesn't get me in trouble with NI!). Best of luck to you!
<-*DrkOvrlord*->
