11-20-2008 12:00 PM - last edited on 01-12-2009 09:14 AM by Support
Hello Sir/Madam,
Question:
We are using the Funktiongenerator NI-PXI-5421 and simply want to generate a pulse, as it can be done by almost every cheap Funktiongenerator.
Unfortunately, I can't find a way to tell the Funktiongenerator to generate a pulse. I can generate Singals as I like but don't know how to generate a single pulse.
Do you maybe have a program which gives me this possibility?
Thank you for your support.
Solved! Go to Solution.
11-24-2008 08:20 AM
Hi Jens,
you could try to use scripting of the 5421 board. The following LabVIEW examples:"Fgen Arb Script.vi" or "Fgen Switch Between Waveforms.vi" use scripting to generate waveforms, you could create similarly a script that generates a single DC high level pulse.
I hope this information helps you.
Blase
11-25-2008 09:07 AM - edited 11-25-2008 09:08 AM
