I am working on project to design Synchronizer for my PIV system on LabView. What I have to do is: to generate two synchronized signal one to trigger laser(signal 1) and other for camera(signal 2). The signals will have some time delay between them and signal 1 will go on independently. I have made labview code for this (attached). I have used case structure(signal 2 generator inside this) within while loop to do this. Signal 1 is generated, for while loop iteration divisible by two the case structure condition becomes true and generating signal 2, wait time for loop is 500ms . This gives time delay between two signal as one second (we can control time delay by controlling divisor factor used to for while loop iteration)
The problem is I am unable to write these two signals to my NI USB6212.
