A device with a counter would be better-suited for your application (retriggerable pulse generation, allowing for the changing of pulse specifications on-the-fly). Our AWGs were not designed for this type of application. There is already an example program written to do exactly what you are looking for using a device with a counter (such as a
Counter/Timer or E Series device).
If you have LabVIEW and NI-DAQ installed, you could use the example finder to locate this example:
LabVIEW Help menu >> Find Examples >> Hardware Input and Output >> DAQmx >> Generating Digital Pulses >> Gen Dig Pulse-Retriggerable.vi
I hope this helps!
Sonya W.
Applicati
ons Engineer
