Signal Conditioning
scxi-1160 connector
  I am designing a cutom circuit board module that will be directly mounted on the face of SCXI-1160 without using any
terminal module.  It is written that the connector type of the SCXI-1160 is 48 pin DIN-C male.
I want to get the female type of this connector. I could not find anything on the web in this
Can you Please tell me the part number for this female connector & where I can buy this.
This will be great help.
Naushica
(3,886 Views)
ERNI and Panduit are two companies that have a wide selection of DIN connectors that are compatible with the SCXI connectors. I would recommend contacting them directly. The 48-pin DIN connectors are really just 96-pin connectors with half of the pins removed.
If you plan on using low-voltage signals (<60VDC) then the SCXI-1310 96-pin custom connector will work with the SCXI-1160.
Logan
(3,879 Views)
