Signal Conditioning
ni 9411 maximum cable length
I am working with a NI 9411 module.
I am looking for a spec. for the signal wire, and the maximum length of signal wire
that is suggested between the sensor and this module.
Thanks for any help or suggestions.
(6,115 Views)
nrel1,
Signal wiring depends on a number of factors.  I would recommend starting with the Field Wiring and Noise Considerations Tutorial.  Although it was written for analog signals, it contains important concepts that should be considered in any type of wiring.  Cable construction is one of the most important factors to address.  These construction parameters set impedance properties that will eventually attenuate and/or delay your signal (Ohm's Law).
Most communication protocols set maximum line lengths.  For instance, USB 2.0 has a maximum cable length of 15ft, Cat 5 Twisted Pair has a max length of 300ft, and Fiber Optic has a max cable length of 28 miles.  It all depends on your application and the conditions present.
https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/field-wiring-and-noise-consider...
Alexander M
(6,105 Views)
Thanks for the information, I will take a look at the link.
The signal I am measuring is TTL, basically a pulsed square wave, where the frequency of the pulse varies.
I did some searching and could not find a standard for the maximum cable lenght for TTL.
(6,103 Views)
