01-31-2006 12:00 PM
02-08-2006 06:07 AM
Synchronizing Two PCI DSA Devices with CVI in Traditional DAQ
http://sine.ni.com/apps/we/niepd_web_display.display_epd4?p_guid=EC682AFD63632A14E034080020E74861&p_node=%20DZ52258&p_source=External from the description of this example: "The scheme for trigger synchronization is identical to the one used for E series boards. The Select_Signal function routes the In_Start_Trigger signal from the master board to a RTSI pin. Select_Signal connects this RTSI line to the trigger circuitry of the slave board." So using Select_Signal function and the Start_Trigger signal you can syncronize via RTSI your board. Best Regards AmbuA
