11-03-2008 03:39 AM
11-03-2008 06:16 AM
K C wrote:Hi Candy,
According to Ohm's law (at least at this side of the world ) a current of 4-20mA through a 50Ohm resistor gives a voltage of 0.2 - 1V
Please explain your value of 10-50mV
I do not understand your second question. A accuracy of 0.3-0.4% is rather good I think for transmitters.
Message Edited by K C on 11-03-2008 08:34 AM
KC,
the the input is 50Ohms MAX . ~2Ohm < 50 Ohm ...
I didn't take a look into the datasheet,but maybe R_in=f(Ucc,f,T,Ri_signal)
11-03-2008 06:22 AM
Hallo Henrik,
Maybe you are right, but most devices (sensors, transmitter, repeaters, barriers, etc) I know with 0(4)-20mA I/O have a fixed resistance of 50 or 250Ohm.
But I am working in a small world
btw. who marked a empty post as a solution ? ?
11-03-2008 09:54 PM
11-03-2008 09:57 PM
03-16-2009 11:55 AM
As the previous user suggested you can use a TURCK IMS interface module. (some info on that here - http://www.clrwtr.com/blog.html )
You can also try an ABB/Entrelec or Weidmuller analog signal transmitter/converter (http://www.clrwtr.com/Weidmuller-Waveanalog-20LP-Signal-Conditioners.htm )
09-29-2009 03:54 PM
The Weidmuller signal conditioner link that you have listed here was moved. Please use the following link instead for Weidmuller signal conditioning products.
