10-20-2017 10:32 PM
I'd like to be able to monitor each individual batteries voltage in order to keep the system working properly by changing out batteries when needed.
Is there a way to meter each battery individually? I place a meter on any of the batteries in the series and get the voltage of all the batteries in the series
Thank you
Solved! Go to Solution.
10-21-2017 08:07 AM
That is because you have the batteries in parallel. You could add in diodes to act as a separation between each battery and the rest of the circuit. With the diodes, then the cell with the highest voltage will be the one to draw the current. But you will be able to measure each cell by measuring the voltages before the diodes.
