06-16-2009 04:53 PM - edited 06-16-2009 04:55 PM
You can accomplish the "adjustable" wheatstone bridge by a few other ways, also.
One is to use a transconductane amplifier in a voltage controlled resistor config.
Another is to use a mosfet as a variable resistor.
So, is this harmonic changing? If not, why not just use a notch filter?
06-16-2009 11:18 PM
hi
i don't know how to make the "transconductance.." etc; can you give some references ?
(the frequency does change, it is selected by the user)
thanks
06-17-2009 11:19 AM - edited 06-17-2009 11:19 AM
The LM13700 operational transconductance amplifier datasheet has some application notes that
give some info on building a voltage controlled resistor.
Just wondering, have you done much research to see if the adjustable bridge is the ideal
solution to your problem? There's a good probability that you can dig up an adjustable
filter, or at least a schematic for one that may be simpler to make.
