07-13-2018 12:44 AM
I have taken the data in PICOSCOPE software then I am converting the data in the txt file for LabVIEW when I am plotting the graph of that signal the signal is displayed as amplitude vs. samples how can I change it to amplitude vs. time?
because of this issue I am unable to filter the signal because the signal is interpreted as the single sample as a single second hence by automatically the signal is having the sampling frequency of the 1HZ even thought having the sampling frequency as 1MHz .
how can I solve this issue? are there any alternatives available for signal conditioning?
12-30-2020 01:58 AM
It is a difficult question but not difficult for me. don't know if you've solved the problem yet.
