Signal Conditioning
Wrong offset specifications for the SCXI-1125 module
@Logan_K As for the actual aging of the components... I am not surprised that the warranted specification is much wider than the actual performance of your unit. Generally NI is very conservative with their warranted specifications to ensure that >95% of devices will pass these limits. Assuming a roughly gaussian distribution of performance across devices, the majority of devices would be expected to have significantly less drift than the worst case. Specifications labeled as "typical" are usually a better representation of how the majority of devices will perform.
I know that and I agree with you regarding this, but are the given numbers for the offset time drift OK? If you are with NI can you please check this?
Thank you
Message 11 of 11
(815 Views)
