Signal Conditioning
What is the pass function of the input filter for SCXI AI module?
Highlighted
I am using Labview with an SCXI1100 chassis. For analog input, I have an 1125 and am adding an 1104C. The DAQ card is a 6052E. The application is ATE for PWM power supplies. Most of the acquisition required is relatively low frequency, however - since the card and the 1104 sample at 333kHz, I should be able to pick up the 20-40kHz gate drive waveforms, and extract frequency, voltage, duty cycle, etc. But here's the question:
The cards themselves have 10kHz lowpass filters. What kind of filters? Chebyshev? Butterworth? Etc. Mathematically, I need to figure what exactly I am going to get out of the card. Is it just going to be attenuated? By how much? What's the noise floor at this frequency?
(2,430 Views)
Highlighted
The manual on page A-3 has some useful information. I am posting it below. Additionally, I found that the SCXI-1104 series use a two-pole RC Butterworth filter. As you'll see in the notes below the 10kHz cutoff is the -3dB point for the filters.
Filters
Cutoff frequency (?3 dB)
SCXI-1104 ............... 2 Hz
SCXI-1104C ............. 10 kHz
NMR (60 Hz) ............ 40 dB (SCXI-1104)
Step response (either gain)
Accuracy SCXI-1104 SCXI-1104C
To 0.1% 1 s 200 ms
To 0.01% 10 s 1 ms
Hope this helps,
John N
Applications Engineer
(2,430 Views)
