10-07-2017 12:22 AM
I want to measure voltage into 50 ohm input impedance of in high speed digitizer.
bandwidth of signal is upto 500Mhz and voltage is upto 250V peak.
Before buying digitizer, I checked effect of input impedance as 50 ohm, voltage used here 230V AC using active diffrential probe.
DSO showed 183V instead of 230V in 50 ohm termination.
I believe same thing will happen with digitizer, then how can i measure correct values in digitizer, cause it do not have 1Mohm input impedance.
10-09-2017 03:37 PM - edited 10-09-2017 03:49 PM
500 MHz and up to 250 V into a 50 Ohm load? Shure?
Get a 1.5 kW 20dB attenuator 😄
Current can make you small, black and ugly ...
However I have the impression that you want something different... but dealing with high voltage and not really cheap digitizers and don't know how to ask questions or define your requirements ....
10-16-2017 04:21 AM
Many thanks for your response.
I will find solution for my problem.
May God bless you with good health !!!!!
