Signal Conditioning
Using "slip rings" to connect to data acquisition equipment
I would like to know about anyone's experience using slip rings for connecting to data acquisition systems.
I am working on a project to instrument a centrifuge. A slip ring is used to connect electrical signals to equipment inside the centrifuge. SCXI will be used in the centrifuge for the signal conditioning and a PC with a DAQ board will be located outside the centrifuge for data acquisition.
What issues will I face with regards to the analog signal and also the digital control signals?
Thank you for your response.
Ed McConnell
(3,728 Views)
Ed
You can bet there will be a tremendous level of noise on the lines. The system effects will be relative to the signal to noise. If you have enough space and power to support an SCXI chassis, I would strongly suggest you investigate using a Minidat from Viasat. It is an wireless ethernet (Cisco Aironet) pc card holder using any AI card that is compatible with RDA. Data rates are 150K-200K samples/sec.
(3,728 Views)
Ed;
I believe the main issue there is going to be noise.
I'm not familiar with that equipment of yours, but, if a slow sample rate is allowed, the best way to go about that is to use a 4Hz filter in to get rid of the noise. Some SCXI modules have that built in and can be enabled in MAX.
Hope this helps.
Filipe A.
(3,728 Views)
