I am using an SCXI 1001 chassis with SCXI 1102 cards attached to TBX 1303 units and also SCXI 1121 cards attached to TBX 1328 units. I need to measure a number of K and T typre thermocouples in this system (using 1102 cards), and was hoping to use a PT100 RTD for my Cold Junction Compensation. Is it possible to achieve this by using the excitation current from an 1121 card and measuring the RTD value with the 1102 cards. It seems that when trying to select the CJC source in Max in the 1102 setup screen, there is no capacity for reading values from cards other than 1102 cards i.e I can't read the 1121 values.
What is the best way to achieve this using the setup I have?
