06-11-2009 12:29 PM
The effect seems follow the trend of what the temperature is doing, it just doesn’t read the right temperature at all times. Drawing a line between the stairstep points would probably give us what the temperature profile is actually like.
The effect only happens on the thermocouple data, and the time delay between stairsteps is much longer than our data rate.
Connecting a thermocouple to all 32 channels did not do anything to correct this effect. We see the stairstepping no matter how many of the channels we leave floating.
If we assume that it’s not a software issue, what would the next step be in troubleshooting? For your reference, we’re using a SCXI-1600 USB device connected to an 1101-C thermocouple box. Any help you can offer would be appreciated.
06-15-2009 07:14 AM
HI cm_opi,
I'm quite curious as to what you sampling rate is, and what your number of samples is- could you please post those numbers? Another question I have is, what kinds of thermocouples are you using? Have you tried using any different thermocouples. Or, is it possible for you to try out a different terminal block with the thermocouples you have? Please let me know, thanks!
07-05-2009 10:01 PM
