Signal Conditioning
TC01 logging period frequency
Just opened the TC01 and plugged it in with spreadsheet logger working OK.
1. How can I get the minimum 4 samples per second sampling rate.  It appears I can only set the pull down menu to once per second.
2.  Is there a way to export a tab or comma delimited format for excel so it opens directly without the need to parse the data in Excel?
thanks.
Brian
(8,014 Views)
Accepted by topic author schreib
Hi Brian,
I found some documentation on our website they you may find helpful. I have included some links below that discuss the questions that you have posted.
Taking Measurements in NI LabVIEW with Your NI USB-TC01
Travis Ann Nylin
Customer Education Product Marketing Manager
(8,004 Views)
thanks Ann.
I will read these over.
Brian
(7,985 Views)
I have the same question about sampling rate.  According to NI website, the USB-TC01 samples up to 4/sec.  Is the only way to achieve this rate by downloading extra software (LabVIEW)?  If so, this is an additional expense that should be noted on the NI website.  If not, how can I get my new USB-TC01 to sample at 4/sec?
(4,240 Views)
