Signal Conditioning
Self-Coded Lowpass Filter
I'm fairly new to LabVIEW, and struggling with implementing a self-coded lowpass filter in my code. It works fine for simulated sine waves (as can be seen below). However, when attempting to lowpass load cell data acquired from a DAQ assistant, something strange happens. The baseline of the filtered signal is offset from the unfiltered signal, and the offset increases with decreasing cut-off frequency. I've attached the VI for the lowpass filter. Any help or insight would be greatly appreciated!
(4,615 Views)
Accepted by topic author mikarn91
Hello mikarn91,
Welcome to the Forums! I made a test-vi to wrap around your VI, to make it easier to test it. I attached it in LabVIEW version 2016, you should be able to open it. (You probably have a similar file, feel free to attach it as well, makes the hurdle to start looking into your issue lower for others Smiley Wink)
I think I found your mistake: Removing the Negate in your Filter it workes much better for me.
Ingo – LabVIEW 2013, 2014, 2015, 2016, 2017, 2018, NXG 2.0, 2.1, 3.0
CLADMSD
(4,588 Views)
Wow, talk about being blind to my own code. This fixed everything. Thanks!
(4,571 Views)
True Smiley Happy
Thank you for the feedback; I am happy we could help that fast!
CLADMSD
(4,557 Views)
