I am attempting to get a SCXI signal conditioning system online collecting data and had a few quick questions... First of all what I have is 1 SCXI 1000 chassis, an assortment of modules including SCXI 1121, SCXI 1180, and SCXI 1100. I also have a couple of different terminal blocks, a SCXI 1300 and a 1320.
1) Per the "What you need to get started" section in the "SCXI chassis user manual" all the only hardware I need is the SCXI Chassis hardware (in my case the SCXI 1000), a 120 VAC power chord, and a computer. However in the "What you need to get started section" of the "Getting Started with SCXI" manual I also need an SCXI 1200 or "DAQ Device". So my short question is this, can I attach the SCXI 1000 directly to my laptop without any additional hardware? I get the feeling I need something else, but want to make sure...
1b) Assuming I do need an additional DAQ device to get started, can I somehow use a NI USB 6210? I checked the manuals and little is said regarding SCXI.
2) Neither manual mentions a controller, however the SCXI advisor pushes one. Are they required if all I am doing is collected data, not active control?
Mike
