Signal Conditioning
SCXI-1600 with 1520
Flat signal with SCXI-1600 from sensors connected to SCXI-1520 with 1314 block while configuration of all modules and devices is OK.
No response from load cells.
In 1520 Test pannel of MAX no real signal can be reached.
With connection over E series card worked good.
When I set up "Strain" in data neiborhood, signal works well.
However, when I set up "voltage", there is no real signal (flat=0).
Is Strain value calculated by voltage?
Why I get the strain signal only, not voltage.
the configuration is:
SCXI -1000
SCXI -1600
SCXI -1520 with 1314.
Labview 8.5
latest DAQmx
(7,058 Views)
I solved this problem.
(7,048 Views)
See posting at the NI forum 'always' helps  Smiley Very HappySmiley Very Happy
(7,041 Views)
But how?
(6,206 Views)
