07-26-2005 05:12 PM
07-27-2005 05:42 PM
07-28-2005 03:55 PM
Otis- Thank you for the feedback, but what is the best way to achieve the overall gain of 0.22 (as depicted in the specifications table for the SCXI 1121). On reviewing the manual, it appears that you can easily set the gain in the SCXI 1121 to "1". This gives an allowable input voltage range of +- 5V.
If I were then to set the 1327 attenuator to 1:1, the 10-14V input would exceed the +- 5V that is allowable on the 1121. Could you please clarify how I should achieve the desired gain value to achieve the +- 25V range?
07-29-2005 04:36 PM
