09-13-2007 12:12 AM
09-13-2007 07:32 AM
One piece of the puzzle you left out is the DAQ card being used in the host computer.
Without looking at some specifics on the SCXI cards/connectors you are using, I will comment you must be careful when you are using an 1180 feedthrough module. Keep in mind, the SCXI chassis is Signal Conditioning -- it's nothing without the DAQ.
I would recommend you back up a few steps, simplify the setup and test each input channel from MAX -- making sure you aren't overlapping channels between the 1180 to the DAQ and the SCXI chassis. Remember, most data from the SCXI chassis comes in on a single channel of the DAQ through the 1349.
Hope this might help.
RS
