Hello NI,
I am using a SCXI-1001 rack with SCXI1100 channel interface cards to read analog voltages from our lab equipment. Setup of the rack was very straight forward and the rack is working properly.
I read (with moderate comprehension) the SCXI 1100 manual and used your SCXI-1100 Voltage.VI as a starting point for the development of our own SCXI 'channel polling' VI.
In the SCXI-1100 Voltage.VI, there are two parameters
1 - number of samples to average for each datapoint - default 100
2 - number of scans per second - default 200
If I interpret this correcty (and use these defaults), this means that 100 datapoint / 200 scans per sec ===> .5 sec (500 msec) to poll each channel. Can you please confirm that I am int
erpretting this correctly ? If so, my question is, can I poll each channel in the 10 msec/channel range (or possibly even faster) ?
I understand that I need to address the set-up and settling time when measuring each channel. I also understand that I should just try running the rack at the faster speeds. I am not sure what polling rates the SCXI rack will support. I assume it is in the micro second range. I would greatly appreciate your comments as a 'sanity check' for how I am using this device.
Thank you,
Larry Scott
OSRAM Display Engineering
408-456-4072
