07-05-2011 04:21 PM
I am using an SCXI 1000 chassis with an 1102 module. It reads negative DC voltages ok. But it does not read posititive voltages properly above about +4V. I believe that I have isolated the problem to the chassis because I have replaced the chassis with another, keeping all other hardware (module, terminal block, cable, DAQ board) the same. With the replacement chassis, results are fine. I have also checked the fuses behind the fan, and they seem to be ok. Can anyone provide any guidance? Thanks.
07-06-2011 03:45 PM
Hi TomDrJ,
Have you tried to use any other modules in this chassis? Will any of these devices work properly?
07-07-2011 10:16 AM
This bad SCXI 1000 chassis also had the 1163 module (digital outs) as well as the 1124 module (analog outs). Once that I determined that the chassis appeared to be having a problem with analog inputs on the 1102, I switched it out for another SCXI 1000 since I needed a running system for my operations. Do you think that testing the bad chassis with either the 1163 and/or 1124 would provide useful evidence? If so, I can try to find the time to bring it back on-line and do such testing.
07-08-2011 10:50 AM
Hi TomDrJ,
It sounds like it is in fact a problem with the SCXI chassis. I would recommend giving us a call so that we can start walking through the RMA process. Please create a service request on our website at: http://sine.ni.com/apps/utf8/nicc.call_me
Let me know if I can answer any other questions for you.
