Signal Conditioning
Replacing an SCXI-1102C
I have an SCXI-1102C that is suspect (getting low level square wave 'noise' at precise 1 second intervals on several channels) and I wish to replace it in the course of troubleshooting. It is mounted in a PXI-1052 chassis. I am relatively new to this stuff. Is is possible to simply power down the chassis and replace the card, or do I need to remove the card from MAX, power down, replace the card, power back up, and re-install the device and all instruments in MAX? Either way, I'll need to recalibrate all affected instruments (we do end-2-end calibrations), but the former method would be a lot easier. Thanks for any assistance.
(5,863 Views)
Accepted by topic author Habaneroguy
Habaneroguy,
Yes, powering down the chassis and replacing the card will work fine.  You shouldn't have to change any of the configuration for the other devices in MAX.
-Christina
(5,843 Views)
