Recently, I have bought USRP B205mini board. I am working on it. I have downloaded the UHD driver from the ubuntu package(sudo apt-get install libuhd-dev uhd-host).
When the board is connected to the PC it is detected when I give the uhd_find_devices it shows the serial,name,product and type.
So, I have written the code for receiving the data. When I am build the code it doesn't show any error. When I run the program some API functions are working fine. when it reach the uhd_rx_streamer_issue_stream_cmd(rx_streamer,&stream_cmd); and uhd_rx_streamer_recv(rx_streamer, buffs_ptr, SAMPLES_PER_BURST, &rx_metadata, burst_duration, false, &items_received); it automatically terminates the program.
When I debug line by line, after reaching the above function it shows like No source available for "uhd_rx_streamer_issue_stream_cmd() at 0x7ffff7227cfe" . What may be the issue?
Also I want to configure the GPIO pins in the board. For that I need GPIO bank name, Can you give me the GPIO bank name of this board?
With regards,
Kavinraj.
