In the Front Signal Connector of the SCXI-1104C module is available a pin (A1, +5V), with the description "+5VDC Source".
In the Appendix A of the User Manual, I see that the power requirements of the module (5V supply) is 15 mA max.
This means I can use only 35 mA from this power terminal? The "SCXI Bus System Specification" refer to 50 mA per Slot of +5V (Average, with SCXI-1000 Chassis).
