06-28-2010 11:24 AM
I am using an SCXI 1000 unit with a 1180 board and a 1302 terminal block. I have been searching though the database for help on the pinmap for the 1302, but I keep on getting "Error:You are not authorized to view this document" even when I am logged in.
examples:
http://forums.ni.com/t5/LabVIEW/SCXI-1302-pinout/m-p/579610?requireLogin=False
I want 8 analog input channels onto the board for 8 pressure sensors. According to Measurement & Automation Explorer, I should connect pin 34 to 68, but there are only 50 pins on the 1302. I cannot seem to find the pin layout for my setup. Any help would be appreciated.
Solved! Go to Solution.
06-28-2010 11:33 AM
It appears I just found the answer to my own question.
This is for anyone with the same questions I had.
The 1302 has a pinmap according to this file which I found some time ago, but only just re-found again. It is a map showing the pin task, the 68 pin version and the 50 pin version.
Sorry about the post. Always seem to find things five minutes too late.
06-28-2010 11:47 AM
Back again,
This time, things are not working.
I was working with the pinmap and Measurement & Automation Explorer and it keeps on making a pin layout on pins that don't exist on the 1302.
In particular, pins with a -voltage signal going to them in the wiring diagram window did not exist on the board.
I have 16 analog input channels and I am using 8 pressure sensors with an external excitation. The pressure sensors are wired the same as a strain gauge.
What do I do to make the Measurement & Automation Explorer give me a setup with the available pins?
06-29-2010 09:03 AM
Hi Nicholas-
Here is a KnowledgBase article that discusses configuring the SCXI-1180 in Measurement and Automation Explorer (MAX). There is also a myriad of related links in this article that will help you along the way.
I hope this helps. Best of luck with your application!
