Signal Conditioning
Periodic "Shark Fin" Unipolar Noise (200mV) on USB-6001 with SMPS - Is this Aliasing?
I am working on a Uniaxial Testing Rig using an NI USB-6001 and dealing with some persistent periodic noise that I can't seem to filter out via software without causing massive lag. I’m hoping someone can verify my diagnosis or suggest a hardware fix.
The Hardware Setup:
  • DAQ: NI USB-6001 (Sampling at 1ks/s 20 kS/s).
  • Sensor: Load Cell + Signal Conditioner (-5v to 5v Output).
  • Power: The conditioner is powered by a Meanwell LRS-350-24 SMPS (24V, Isolated).
  • Wiring: Differential Mode (AI 0 to Signal+, AI 4 to Signal-).
  • Grounding: I have a 10kΩ bias resistor installed between AI 0 and AI GND to handle the floating source.
The Issue: Even with the sensor completely unloaded (static), I am seeing distinct, periodic noise spikes of around 200 mV.
  • Waveform: It’s not random fuzz. It looks like "shark fin" pulses (fast rise, slow decay).
  • Frequency: At 20 kS/s, I see exactly 5 peaks per second (5 Hz).
  • See Attached Image: [Insert your Green Graph Screenshot Here]
My Theory: Since the Meanwell SMPS likely operates in "Burst Mode" at light loads (switching frequency >50 kHz), I suspect the USB-6001 (which lacks hardware anti-aliasing filters) is aliasing this switching noise down to 5 Hz.
Questions:
  1. Has anyone successfully filtered SMPS switching noise on a USB-6001 without external hardware?
  2. Would a simple RC Low-Pass filter (e.g., 1kΩ / 10µF) at the screw terminals be safe for this specific DAQ's input impedance, or will it cause gain errors?
  3. Is there a specific Digital filter that would help me handle this noise?
Any advice would be appreciated!
Message 1 of 1
(811 Views)
