Signal Conditioning
Part Number for parallel cable connecting SCXI-2400 to SCXI-1200
If no longer available from NI, would anyone have the (upper) rear connector pinout for the SCXI-2400 so I can make my own cable using half of a DB-25 parallel printer cable and the appropriate AMP connector?
(5,578 Views)
I'm not sure which of the two connectors is the upper one, but there are two connections. One of them uses an RS-232 cable connection and the other is just a 4 wire RS-485 terminal block connector. The latter of the two has a pinout shown here in this article. Here is another useful article that addresses setting up your chassis. I hope this helps.
Chris W
Message Edited by Chris W. on 02-12-2009 04:52 PM
(5,562 Views)
