Signal Conditioning
PCB signal conditioner electric noise
Hi!
I am using the piezoelectric pressure transducers with NI card along with PCB ( 482A16) signal conditioners for pressure measurement. The signal conditioners are showing up noise peak at 50 Hz frequency and above. Is this because of the cross talk between the channels or something else? I ensured that the grounding of the whole measurement set up is proper.
Please guide for the problem.
With regards,
Ganesh
(5,745 Views)
Do a measurement without a sensor: Replace the ICP sensor(s) (I assume you have a ICP sensor) with  a resistor R=10V/<supplycurrent>  directly at the amplifier input.
If you still have the noise it is probably the powersupply of the amplifier. BTDT
Greetings from Germany
Henrik
LV since v3.1
(5,719 Views)
