Signal Conditioning
NI-Daq 6.9.2 Patch for null offset on SCXI 1520
Does my current upgrade include the recent patch to fix null offset problems?
(3,484 Views)
Hello, there was an issue with NI-DAQ 6.9.2 that was not in previous versions of the NI-DAQ driver regarding the offset nulling routine for the SCXI-1520. This problem was fixed, and a patch to the NI-DAQ driver is available.
Please contact National Instruments Technical Support for a copy of this patch file.
The NI-DAQ 6.9.2 driver with this patch file is the optimal version for use with the SCXI-1520. The offset nulling routine has been optimized to take less time, and to perform a hardware null to extremely low (if not zero) voltages.
(3,484 Views)
So if I am using NI-DAQ 6.9.1 with the SCXI-1520, should I upgrade to NI-DAQ 6.9.2?
(3,484 Views)
