Signal Conditioning
MAX Simulated Device SCXI-1001
I open "Measurement and Automation Explorer".
Right click on "Device and Interfaces".
Select "Create New".
Select "NI-DAQmx Simulated Device".
Press "Finish".
Expand "SCXI Chassis".
Select "NI SCXI-1001".
Press "OK".
Window "Create New SCXI Chassis" appears.
("Chassis Communicator" does not allow a selection)
"Chassis Address" set to zero
Press "Save".
Window "Chassis Communicator" not picked with message "Please pick the communicating DAQ device."
My system does not have an SCXI-1001 attached. Our equipment is being shipped to the
installation site. We need to continue software development and test.
Can you tell me if I can simulate the SCXI-1001 without the SCXI being attached to my computer?
This function worked when I tried it on the computer that had the SCXI-1001 attached.
Is there a work around for his issue?
Thank you for your help.
Bill
(3,359 Views)
Hi Bill-
In order to configure a simulated SCXI chassis you will first need to create a simulated DAQ card to serve as the chassis controller.  I would suggest a simple multifunction I/O board such as the M Series PCI-6221.  Please post back if you are still not successful.
Thanks-
Tom W
(3,354 Views)
I set up the configuration exactly like the actual hardware, doing the PXI modules first, and it works correctly now.
Thank you for your help !
Bill
(3,350 Views)
I'm glad I could help- let us know if you need anything elseSmiley Happy
Tom W
(3,347 Views)
