Signal Conditioning
Level Sensor Output Signal: 240-30Ω, Is it possible to measure with PXIe 4300?
We have an electrical motor that we run at roughly 50HZ which creates signal interference with several sensors we have connected to our DAQ systems whenever the motor is turned on.
Is there anything that can be done to reduce this interference? The motor is controlled by a controller which are connected via a shielded cable, and all of the instruments are grounded and connected using a shielded cable as well.
Thank you!
(3,060 Views)
The first thing to do is a documentation of all(!) wires and and contacts (grounding) you have in your setup.
Start with the power lines on one side and work to the other side to the DUT.
Mark ground connections you can't change (savety, (stupid desingned) sensors that connect power supply to GND/housing,...)
Collect all datasheets ...
Motor SPSUs are prone to create EMI. A filter between SPSU and motor can help, together with a grounding strategy (central, depending where the ground currents flow...)
Electric motors create (and work with;) ) magnetic fields, you can't shield with copper. Reduce wire loops, use twisted pair cables, route the cables crossing less magnetic field lines and finally use IRON to shield (change mag field lines).
Greetings from Germany
Henrik
LV since v3.1
(3,044 Views)
Hey mjed,
I think Henrik_Volkers provided some great next steps. I just wanted to provide you with some documentation to read over that might help make the wiring of your system better or how to deal with the noise if the wiring cannot be helped.
Field Wiring and Noise Considerations for Analog Signals
https://www.ni.com/en/shop/data-acquisition/measurement-fundamentals/field-wiring-and-noise-consider...
Five Tips to Reduce Measurement Noise
https://www.ni.com/en/shop/data-acquisition/five-tips-to-reduce-measurement-noise.html
Hope these help!
Gerald M.
NI
(3,037 Views)
