Signal Conditioning
LabView Equipment needed to controll a large servo
Hi, I have this project in university, that I have to make a system, that moves servo motor back and forth fast and accurately. Unfortunately, it is not a small servo like we are used to and thats why I would like to know, if it is possible to control bigger servos (220V) and what components do I need for that.
(3,579 Views)
A servo could be any motor with a (angular) position sensor...  in the best case including a power controller with matched controller values that only needs a position (or speed, or ..)  command via analog or digital signaling.
The joy of engineering is to do what you want, with the stuff you can get ... so: What do you have or what can you get?
Greater energy is followed by greater responsibility ... so controlling bigger engines usually includes more safety constrains 😉
Greetings from Germany
Henrik
LV since v3.1
(3,547 Views)
