This is a good introductory article on how strain gauges are used in conjunction with signal conditioning. However, it's not clear how this relates to measuring bridge resistance. We make full bridge force measuring sensors that use strain gauges. (i.e. tension or compression load cells) The calibration report that I need to generate using LV must also indicates the bridge resistance for both input and output. (Previously I mentioned only the input.) Currently, we take a common ohmmeter and manually measure the resistance and then record the values on the calibration certificate. The sensor is not under any load while measuring the resistance. Even if it was under load, you probably would not see any change in the bridge resistance. (The mV/V output
is very low for typical load cells.) At this point I�m trying to figure out the best way to automatically do this using an SCXI-1520. In other words, I need to use one of the channels of the 1520 to operate as a common ohmmeter and I'm looking for ideas on how to do this.
