Hello Eric,
I think you mentioned the correct way to make this work. You need to group the cjtemp of each module with the other channels of that module. I did this with a setup of my own, and everything worked fine. Is it possible that the second cjtemp was just immediately overlayed by other channels and appeared not to be there?
If this is still an issue for you, please explain what you mean by 'ignore the second cjtemp command'.
Thank you,
John Nieri
Applications Engineer
