I am trying to scan the excitation channels for the SCXI-1520 from Measurement Studio 7.0. When I try to do this an error reading:
Excitation Property must be the same for related physical channels
I am setting up the strain signal as a voltage channel with excitation and the excitation as a regular voltage channel. The excitation is first in the scan list and the strain signal is second.
Attatched at the bottom is my configuration routine.
The 1520 is in an SCXI-1001 chassis along with 1 SCXI-1140 and 2 SCXI-1125. The SCXI-1520 has the 1314 terminal block and the 1125's have the 1313 terminal block. The 1140 is feed from the back plane of one of the 1125's.
