04-13-2009 01:07 PM
05-31-2009 01:22 PM - edited 05-31-2009 01:24 PM
Hi EzaL,
Let me see if I understand it correctly. You have two controls on the front panel: one is a slider, and the other is a button. If the button (gate?) is pressed, the slider slowly changes value (down). Is this correct?
If so, you can use property nodes and a timer to do this. Create a property node for the slider with two elements: disable and value. See the attached vi as a possible solution.
Hope this helps
Darrel
06-04-2009 08:02 AM
Agile has supplied a great answer, with code. I doesn't get any better than that.
I wish one-hit-wonders would at least check back in and say Thanks when help is offered.
06-04-2009 07:33 PM
Broken Arrow wrote:Agile has supplied a great answer, with code. I doesn't get any better than that.
Thanks! I and understand why the original poster hasn't replied. It's been six weeks and no one answered him. *sigh* At least it's there for the greater community. If someone ever does a search on slider control, they may find this.
Kudos!
06-04-2009 08:34 PM
Agile wrote:
... been six weeks and no one answered him...
True, he probably gave up or hasn't checked his email, so to him (her?) I'm sorry for jumping the gun, but I have seen too many of these members that log in once or twice and get good answers and don't check back in. It erks me. You make a good point though, that the thread has a wider purpose than that of helping the originator.
