Signal Conditioning
How can I bypass a potentiometer that feeds into a drive controller by using an SCC-AO10 module? Which wires must I cut and where should they connect to the SCC-AO10 module?
I think, in the case you want to combine both potentimeter and LAbview, you best read the position of the potentiometer into labview (1 connection ground, 2nd connection +Vcc, 3rd connection to the labview module)
In your Labview program you can now combine the potentiometer position with whaterer other setting, calculation or reading.
I
Message 11 of 11
(3,162 Views)
