Signal Conditioning
Filter Point by point
Thank you very much.
I have this question because I see that If I use 1Hz sampling rate and cutoff frequency 0.015Hz for the Butterworth filter (PtbyPt), the output is the same as that of the normal Butterworth filter (fs = 1000Hz and fc = 10Hz).
I really want to know clearly about this digital signal processing. I see that at each time = k/fs (k = 0, 1, ...N-1 and fs = sampling rate) the FOR LOOP will implement one calculation/loop --> the filter (Pt by Pt) must be 1Hz at k/fs with fc = 0.015Hz. Otherwise, we consider a digital array of the input with 1000Hz sampling rate --> the normal Butterworth has fs = 1000Hz and it of course has 10Hz cuttoff frequency. In two cases the fc/fs is the same.
Thanks.
Dong
Message 11 of 15
(2,362 Views)
See, you have the same array of numerical values, and apply the same numerical filter kernel ...(determend by fc/fs, look up digital filter design 🙂 )
but why that is of any importance? Usually you have to deal with real word data 😄
Greetings from Germany
Henrik
LV since v3.1
Message 12 of 15
(2,356 Views)
Dear Mr
Message 13 of 15
(2,348 Views)
You should only present and explain things you have understood ... if you don't want to blame yourself 😄
To your question:fc/fs can be one (beside others) coefficient that is important for certain tasks...
al lot of other  boundary conditions.  .. definitions ...  have to be regarded... mostly taken for grand ..
And a forum can help with some details ... but the basics are best learned by a structured lecture/book/seminar....   depending on prior knowledge, may take more or less time ...
and need motivated wett cells between your ears 😉
in your case: numeric signal processing
Henrik
LV since v3.1
Message 14 of 15
(2,337 Views)
Dear Mr
Message 15 of 15
(2,333 Views)
