Signal Conditioning
Does scan mode do low pass filtering
When using scan mode, does it digitally low pass the signals before it outputs the data to me? (I have a 9206 that can sample in 250kHz but scan mode runs at 1kHz)
/thomas
(3,084 Views)
In scan mode, data is captured at a lower rate, as you mentioned.
You can set your NI-9206 to FPGA mode and capture the data at a much higher rate, if your chassis contains an fpga chip.
(2,983 Views)
