Signal Conditioning
Reply
Can the SCC-A10 channels be connected in series?
Can the 2 channels of a SCC-A10 voltage attenuator modules be connected in series to measure 190 volts DC?
(1,174 Views)
Re: Can the SCC-A10 channels be connected in series?
You can't cascade two SCC-A10 modules because this module can't support being on the second stage of this configuration. To find more information about which SCC Modules Can Be Cascaded or Used in Dual Stage Mode, please refere to the following knowledgebasek. You may want to consider using an SCXI module instead of an SCC one.
Hope this helps,
LA
(1,170 Views)
