02-26-2014 09:58 PM
Sorry if this is the wrong place to ask this question...
I want to use an SCXI-1141 to make some really small voltage measurements. The only terminal block that I have is the TBX-1303. Can I connect the two to do this?
m
02-27-2014 01:14 PM
Hi mvilla,
This is a great board to post your question. Unfortunately, you cannot use the SCXI-1141 with the TBX-1303. The TBX-1303 is designed for thermocouple measurements and can be used with the SCXI-1102B/C, SCXI-1100, or SCXI-1181. You can use the SCXI-1141 with the SCXI-1304 or SCXI-1305. Here is a great document about terminal blocks to help you with your future decisions.
SCXI Terminal Blocks: http://www.ni.com/pdf/products/us/4scxisc326_ETC_332.pdf
Anna L
