We use the SCXI-1520 signal conditioner to test and calibrate bridge sensors that we manufacture and it works great. While the system is not used (i.e. when the operator connectes a sensor to the system) the SCXI-1520 is automatically isolated by using relays in a switching system. The primary intent for this is to avoid possibly damaging the signal conditioner. (Operators do regretful things.) This means that the excitation power is floating with no load while the signal conditioner is disconnected,. I was wondering if it would be appropriate to have the system automatically apply a load resistor to the excitation source to keep it "warmed up" so to speak. Most sensors are a 350 ohm bridge and may be as high as 5000 ohms. I was thinking of applying a common 330 ohm 1/2 watt resistor as a load. (We are currently only using two channels at a time.) Although I'm sure it would not make things worse, I just wonder if it's worth the bother. Please advise...
